Having problems downloading
Discussion in 'Archived Threads 2001-2004' started by Jon_Are, Apr 8, 2002.
  1. Jon_Are
    Jon_Are Cinematographer
    Jun 25, 2001
    2,036
    Hi...I recently had to re-install Internet Explorer 6.0. Now, whenever I try to download, I get this: the screen is blank (white) except for a very small box in the upper right corner with a circle, triangle, and square, each a different color. The bottom of my window says 'done', as if something was actually accomplished. There is no window that opens asking where to save the file, etc.
    Is there a setting in IE that needs to be changed? Any other ideas?
    Thanks!
    Jon
  2. Travis Olson
    Travis Olson Supporting Actor
    Oct 7, 2001
    937
    Travis Olson
    Sounds like something went wrong with the installation. Did you download IE 6 from Windows Update or was it from a Windows CD? If you got it from Update, chances are it didn't finish downloading, try downloading and reinstalling it again. I had a simialr problem when I got it from Update when I had WinME.
  3. Jon_Are
    Jun 25, 2001
    2,036
    Thanks, Travis. I installed version 4.0 from an older disc I had, then downloaded IE 6 from Microsoft. Guess I'll try doing this again.
    Any other ideas??
    Jon
