Having Cox & a PS2 connection is not good...
Discussion in 'Archived Threads 2001-2004' started by Calvin Watts III, Aug 29, 2002.
  1. Calvin Watts III
    Calvin Watts III Supporting Actor
    Mar 7, 2001
    916
    I'm having serious problems getting online with the PS2.
    I called into Cox, & they were of no help at all.
    I was able to figure out, by trial,error, & some luck, my internet settings.
    Now I'm online, but i can't send my info to Sony.
    Therefore I can't play any of Sony's games.
    Has anyone else run into this sort of trouble, & can anyone help out?
    Calvin
  2. Rob Speicher
    Rob Speicher Supporting Actor
    Nov 24, 2000
    935
    What kind of settings, like DNS servers? Just plug the modem directly into your NIC, go to a dos window and do
    ipconfig /renew (if needed)
    ipconfig /all
  3. Calvin Watts III
    Mar 7, 2001
    916
    Well, after calling back Cox - I got somebody to finally help me out - & I'm online (I hope).
    Anyways, I need to reset my cable modem each time I switch between my iMac & my PS2.
    Or I was told I could get another IP address & that would take care of that.
    If the resetting of the cable modem works, I'll stick with that for now.
    Any suggestions?
    BTW - Rob, thanks for trying to help [​IMG]
    Calvin
  4. Chad Ellinger
    Chad Ellinger Second Unit
    Jun 18, 2000
    269
    Sounds like you need a router. This will allow you to split your cable modem connection between your iMac and your PS2 and use both simultaneously. Expect to pay around $40-70 for one. There are many good threads in the Computer/HTPC Forum about how to set it up.
    http://www.buy.com/retail/computers/...ry.asp?loc=413
  5. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    Indeed. I'm using a Netgear router hanging off of my Cox cable modem, and have had zero problems getting my PS2 online and connected to wherever I want...
  6. Calvin Watts III
    Mar 7, 2001
    916
    Now let me get this straight...
    (this helps avoid "discussions" with the other half)
    If I go out & get a router - I won't need to get another IP address?
    Meaning I can split my current connection 2 ways without one?
    If that is the case, then I'd save money in the long run...I think.
    I'm also going to eventually take the Xbox online, & maybe another computer. So I'd need a 4-port one - I'm guessing.
    EDIT: - One last thing - my Cox rep told me that in order to currently switch between my PS2 & my iMac, I have to reset the cable modem each time. With a router, since I'd be able to have all of my things using the same info (DNS,IP addy,etc.) I wouldn't have to do that anymore,yes?
    Need to get my facts straight before I go spending more cash..
    Anyways - I'll take a look. Again,thanks.
  7. Camp
    Camp Cinematographer
    Dec 3, 1999
    2,301
  8. Joel Mack
    Jun 29, 1999
    2,317
  9. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,210
    Just so you know come cable companies consider that a violation of the terms and agreements if you use a router without telling them and paying extra for the other connections. very similar to splitting the cable that comes into your house. Aparently some cable companies arent like this, but you want to be careful.
  10. Camp
    Dec 3, 1999
    2,301
  11. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    Camp is right!
  12. Josh Lowe
    Josh Lowe Screenwriter
    Jun 19, 2002
    1,063
  13. Kelley_B
    Feb 27, 2001
    2,324
    Do you work for Cox Josh?
  14. Joel Mack
    Jun 29, 1999
    2,317
    I can't vouch for Josh, but since Cox has been to my place several times and seen my router setup, I can say that at least the Omaha branch doesn't have a problem with it...
  15. Calvin Watts III
    Mar 7, 2001
    916
    I went out today & got a router.
    Camp, you were right, it was really easy.
    Thanks everyone for your help.
    I appreciate it.
    Seeya online!
    Calvin
  16. Camp
    Dec 3, 1999
    2,301
    Cool! Now you can kill 'real' people! [​IMG]
  17. Josh Lowe
    Jun 19, 2002
    1,063
