Having a technician come to check out my tv, help?
Discussion in 'Displays' started by Jeremy Scott, Sep 17, 2003.
  1. Jeremy Scott
    Jeremy Scott Second Unit
    Mar 29, 2003
    292
    I am having a technician come out next friday the 26th to check out my purity problem on my 36" JVC HDTV.
    I have had it for 2 months and I got a 3 year extended warranty with it.
    What could be the possible interior tv problems causing this???
    My extended warranty SHOULD cover everything, correct?
    I dont want the guy to come here and tell me my tube is busted and my warranty does not cover that...........cause my answer for him will be......then what is the point of a warranty?
    I just got home from work and turned it on and it was pretty good, so i turned it off and right back on and the corners were bad..
    Anyways, can anyone answer my questions??
    thanks
    jeremy
  2. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,210
    I cant really say cause im not sure exactly what your problem is, can you be more specific?
  3. Jeremy Scott
    Mar 29, 2003
    292
    i have purity problems on the corners of my screen, sometimes they are not bad, sometimes they are bad.
    if i turn tv on and they arent very bad, i can turn it off and turn the tv back on and they look terrible.
    i want to know why they come and go.
