Ken Chan
- Apr 11, 1999
- Ken
I'm guessing I should go back and re-encode all my video files without AC-3?Are you using separate "elementary streams", video and audio? I've always seen AC-3 in a separate audio file and the video in its own .m2v or .mpv file. If you got your encoder to mux them together, you should be able to use a demux tool to separate them so you don't have to re-encode.
Too bad you put in all that time already. I would recommend DVD-lab. 30-day free trial, $79. Doesn't have any pretense of encoding, so you just have to feed it compliant files, and it doesn't monkey with them.
//Ken
