Lary Larson
- May 3, 1999
I just learned of this technique and was wondering if anyone here has any experience and/or opinions about it.
To summarize the theory: You strength train by holding the maximum possible weight for 10-20 seconds in the strongest possible position - just short of lockout. No motion (just enough to get the weight into position), no sets, no reps.
You initially start by trying 50% more weight than you normally use for the full-range exercise - if you can hold that for more than 20 seconds, add more weight. There are 2 workouts of 6 exercises each and you start out doing each workout 1x/week (and at 20 seconds per exercise, if you didn't have to do set up, you'd be done in 2 minutes!). During each successive workout, you should be able to lift more weight or hold the same weight longer. If you can't do that, you're overtraining and you should wait longer between workouts. Then, as you increase the weight, you decrease the frequency of the workouts because your recovery time is increased.
The theory behind this method is that by holding the weight in the strongest possible position you're maxing out every fiber of your muscles. You're supposedly getting maximum intensity in your workout by doing more work (i.e. lifting more weight) over less time. Range of motion isn't necessary and is actually eliminated due to the potential for injury. In the studies, after 6 weeks of static contraction training people reported an average 30% increase in the amount they were able to lift using full-range exercises.
This method is for strength training only. You still need to work on flexibility and cardio separately.
Here is a link to one book on Amazon. If you go to www.precisiontraining.com you'll see that these guys have a new e-book out.
I'm curious to hear what you guys think. I'm pretty leery myself, but I like to keep an open mind.
Lary
Lary
