Mark Guidry
- Dec 28, 2001
Ok I have my SVS dual 39+/s1000 combo and I calibrated everything to 75 dB's except for the subs...they are at 80. I also ran some test tones that I have burned onto a CD so I can see my "room curve" and if I would benefit from and EQ. I have no idea what I am doing so please be gentile on me
Ok I don't know if I went over board but I went from 10hz to 100 Hz in 2 Hz increments. I didn't use any of the correction values because I didn't used the exact numbers from the SVS sight and I don't know how to figure them out.
So here are the actual #'s I got in the listen position with my RS meter pointing up about 45 degrees above the center channel
Hz dB's
10 54
12 60
14 67
16 74
18 82
20 88
22 89
24 91
26 93
28 87
30 84
32 81
34 79
36 77
38 78
40 77
42 76
44 72
46 72
48 70
50 70
52 72
54 73
56 72
58 71
60 71
62 72
64 73
66 72
68 72
70 72
72 72
74 74
76 76
78 76
80 76
82 75
84 74
86 73
88 65
90 67
92 71
94 72
96 72
98 69
100 69
200 78
500 72
I saw someone with these last 2...I don't know why, but I did it any way. So what's next...can someone help me do the correction values and tell me what program I can use to get a graph.
I can let you know any other info you might need and I can get pics to. Or I can do it over with less numbers
Thanks every one
Mark
Hz dB's
10 54
12 60
14 67
16 74
18 82
20 88
22 89
24 91
26 93
28 87
30 84
32 81
34 79
36 77
38 78
40 77
42 76
44 72
46 72
48 70
50 70
52 72
54 73
56 72
58 71
60 71
62 72
64 73
66 72
68 72
70 72
72 72
74 74
76 76
78 76
80 76
82 75
84 74
86 73
88 65
90 67
92 71
94 72
96 72
98 69
100 69
200 78
500 72
Thanks every one
Mark
