Have $1k to spned on home theater speakers. Suggestions please
Discussion in 'Archived Threads 2001-2004' started by Thomas Molnar, Jun 30, 2002.
  1. Thomas Molnar
    Jun 27, 2002
    46
    Gang
    I am looking for a set that will be good for movies and music. Thanks!
    Tom
  2. ChaseHanna
    ChaseHanna Stunt Coordinator
    Dec 4, 2001
    55
    I am also interested in spending around 1k for home theater speakers. I was considering getting an SVS 20-39PCi and then matching up the other 5 speakers with that an a Denon 3802. Ill be watching this thread closely.
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Three pair of JBL Series I S26 bookshelves (the Series II just came out and they are clearing out old stock cheap, they are essentially identical to the Series II that they want $320 a pair for) would be $480 including shipping from jandr.com. Then $500 for a SVS 25-31PCi retuned to 22hz plus shipping. Takes you a little over $1000 and gives you an excellent 6.1 system. Provided you don't mind using a bookshelf speaker as a center channel.
  4. Paul_Fisher
    Paul_Fisher Screenwriter
    Dec 27, 2001
    1,219
    If I were you all I would do a search on this sort of subject. There are literally about 20 or 30 different setups depending on what you like. Go and audition different things!!!
  5. Josh Lowe
    Josh Lowe Screenwriter
    Jun 19, 2002
    1,063
    What Paul said. I did just that (searched this and other forums) and decided on the Home Theater Direct Level 3 speakers, "Y" combo. The total on these came out to be $1024 shipped to my door. Initially I was not overly pleased with the center channel, but after some break in and adjustment of my receiver I am very happy with them.
    My second choice would have been the Swan Divas, but they are out of the $1k price range for an equivalent set.
  6. Jeff_Fitz
    Jeff_Fitz Stunt Coordinator
    Jun 2, 2002
    110
  7. Bruce Chang
    Bruce Chang Second Unit
    May 10, 2002
    283
    You can find PSB stratus goldi's for $1100
  8. Roberto Carlo
    Roberto Carlo Second Unit
    Apr 14, 2002
    445
    I'm assuming $1000 for 5 speakers plus a sub. Go to the Axiom Outlet and get two pairs of M2Tis for $192 per pair. Add a VP-100 center channel for $198. Finally, an Adire Rava sub for $399. Total: $981 plus shipping on the Adire. If you're willing to spring for the M3Ti, the cost goes up between $56 and $112. A nice combination, IMO.
  9. Joe Rison
    Joe Rison Auditioning
    Mar 29, 2002
    7
    I second the Axiom/Adire setup. I found it to be the best value out there. My budget was a little higher but was still tight. Might check to see if you can get a deal on a b-stock Rava, sort of like Axiom's outlet. Email them and see if they have any.
  10. Mike OConnell
    Mike OConnell Second Unit
    Jun 14, 1999
    489
    110
    Overland Park KS
    Mike
  11. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,214
    110
    Is it $1K for speakers and sub or only for the speakers? Speakers only I am partial to the nOrh line. Paradigm, PSB, Energy, and Axiom are all excellent choices as well.
  12. Greg Foan
    Greg Foan Stunt Coordinator
    Feb 4, 2001
    50
    Considering DIY? You can build 5 ACI Emeralds for about $860 USD delivered......if you have access to a plunge router, the construction of the cabinets is a snap.
