Have 17" Dell Ultrasharp...What is DVI cable for?? (1 Viewer)
Brian Price
Just got a Dell 17" ultrasharp flat screen monitor and love it! It came with white DVI cable that I could use to hook up to my pc. I am now just using the normal blue cable. Should I use the DVI cable and why/what are the benefits?? Thanks!
Brian Price
JamesHl
If your video card has a dvi out, you could use it to hook up the monitor. I happen to think the picture looks better this way, but it varies from monitor to monitor (doesn't make sense, it should always look better since there is no analog in the signal, but some look worse).
Ted Lee
dvi (i think) stands for Digital Video Input. it allows a full digital signal to be sent to your monitor. the idea is that you get a better picture quality since the video signal does not undergo a digital -> analog conversion.
at least i think that's how it works. my graphics card has the dvi, but i only have an analog monitor. so i can't comment firsthand.
NHCondon
