Has anyone tried to make their own absorbtion panels to tame a room?
Discussion in 'Archived Threads 2001-2004' started by Judy Y, Apr 16, 2002.
  1. Judy Y
    Judy Y Stunt Coordinator
    Feb 27, 2000
    119
    If anyone has, how did you make them? What did you use? I have read about using some sort of fiberglass board used in insulation, but have only seen the styrofoam panels at Home Depot.
  2. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    Go to www.audioasylum.com, find teh FAQ, find the link to Jon Risch's site, and you'll find plenty of stuff on DIY room treatments. Read that, and then go back to Audio Asylum and surf the archives of the DIY forum with the keywords that you want information on.
  3. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    You'll find additional info HERE
    The server is running a little slow today so give it time to load the page
  4. Ryan T
    Ryan T Second Unit
    Sep 10, 2001
    406
  5. ThomasW
    Nov 6, 1999
    2,282
    Ryan
    If you need big time absorption then make the larger DIY fiberglass insulation filled panels. The compressed glass tile absorb no LFE they're too thin. They are handy for first reflection control where the larger panels can't be used.
    They're also cheap, so it's no big deal to get a few and find out if they are beneficial.
  6. Ryan T
    Ryan T Second Unit
    Sep 10, 2001
    406
    I think I might try some of those compressed fiberglass tiles first. If that is not enough then I might go with the bigger DIY panels.
    Ryan
  7. Judy Y
    Feb 27, 2000
    119
    Thanks for all the great links. This is just what I was looking for!
