Has anyone put real wood vaneer over sonotube?
Discussion in 'Archived Threads 2001-2004' started by rodneyH, Mar 30, 2002.
  1. rodneyH
    rodneyH Supporting Actor
    May 22, 2001
    844
    I was just wondering if this has been done, I think it could look nice, anyone try???
  2. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    Check the SVS site. I believe they offer it as a custom finish.
    Pete
  3. rodneyH
    May 22, 2001
    844
    ya, I have seen those, but I was wondering if any DIY'ers have done it yet, and if it is possible.
  4. Pete Mazz
    May 17, 2000
    761
    It's certainly possible. Of course that's based on your ablity to make the seam in the veneer disappear. A larger diameter tube (>15") would require two seams, assuming a 48" wide sheet of veneer.
    Pete
  5. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    I can see the names now:
    Tree Trunk Sub
    SonoTrunk!
  6. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    If you did this I would suggest buying the NBL veneer from Tape-Ease. It comes with a wood backer and would work better than the paperbacked veneer. Since sonotube has grooves in it the grooves would probably telegraph through the paperbacked stuff. Telegraphing is much less of an issue with NBL.
    Brian
    P.S. I checked out my 11 sheets of 10-mil paperbacked veneer (5 oak, 5 maple, 1 cherry) and they look pretty damn good!
