Jim Mcc
If so, was it very hard? Any tips for me? I'm thinking of doing this by using contact cement, and gluing onto Medium Density Fiberboard. I already have the MDF, which is painted(my current screen). In order to use the same MDF, I have to get a wooden cleat(1X3) off the back, which the screen hangs on. I put it on with construction adhesive and screws. Then I would flip the MDF over and glue the laminate onto the unfinished side. If I don't screw it up too bad, I can fill the holes, and re-use this side for the laminate. I just don't know if the adhesive will pull off big pieces of the MDF as I try to remove cleat. I talked to a Wilsonart rep today, and he told me the laminate will not adhere to the paint. He also said to paint backside, and all the edges to prevent warping. A guy at Home Depot today, told me my best bet is to lay a 2X4 down against the wooden cleat, then whack it to get the cleat off. And If I try to pry it off it will just keep digging into the MDF and it will be a mess. What do you guys think? Thanks.
