Has anyone built a small(95L) shiva sub?
Discussion in 'Archived Threads 2001-2004' started by Seungsoo Hwang, Feb 4, 2001.
  1. Seungsoo Hwang
    Seungsoo Hwang Stunt Coordinator
    Aug 6, 1999
    204
    I am about to start making one in the SBB4 alignment from the white papers. Has anyone else made one? How does it sound(I am looking for more mid/upper bass this time)? Do you have a webpage where I might look upon your creation?
    thanks
  2. Mark Hayenga
    Mark Hayenga Supporting Actor
    Jun 11, 1999
    607
    I built an 85L tuned to 23Hz, sounded great. Only downside is you're limited to a single 4" port before vent lengths get out of hand. Several Austin-area HTFers heard mine at a past meet and it seemed to please most everyone there.
    Mark
  3. Mark Hayenga
    Jun 11, 1999
    607
  4. Kyle G
    Kyle G Auditioning
    Jul 25, 2000
    11
    Yup, i've got a Shiva in an SBB4 alignment. Sounds great, but it seems to be a lot more powerful in the 22-35hz region than it is in the 35-60hz. When I built my Parts Express 15"DVC sub and added it to my system, I noticed that the low end was way overpowering compared to the mid-bass. So what I did was I cut down the port length on the Shiva sub to about 6 or 7 inches and now it is tuned to about 33 or 34hz. The whole system sounds great now because I have lots of midbass "punch" and I still get plenty of lows from the 15". I'm only telling you this because as I recall you have a 15" sub also(?). If you do, try what I did, it sounds great! Oh, one more thing, you might think the Shiva would bottom out during low bass scenes in movies because of its higher tuning but surprisingly it hasn't yet! [​IMG]
    "Hearing and listening are two entirely diffrent things"
    www.angelfire.com/movies/myhometheater
  5. Seungsoo Hwang
    Aug 6, 1999
    204
    Thanks for the measurements Mark. They shed some light on things. Kyle, I have the 15" Dayton tuned reall low, about 19hz. This wasnt very satisfactory in the music department for me, lacked the punch I get at the clubs for midbass techno and hiphop that I listen to a lot of. Was the 23hz tuning really unsatisfactory for you? While for now your system would be a good way to go, I will be using this sub solely on its own when I am in college, so I guess going with the orginal 22-23hz tuning would be better to cover more material.
  6. Kyle G
    Kyle G Auditioning
    Jul 25, 2000
    11
    Well, not that the 23hz tuning was really unsatisfactory, it was okay, but the higher tuning on the sub sounds SO much better when paired up with the 15". I get a good amount or that "kick you in the gut" type of bass with both movies and music that I never got before. I'd really recommend doing what I did. Also, since the sub will be tuned higher, you could probably get away with using a slightly smaller enclosure (like 70 liters).
    Good luck with the project!
  7. Seungsoo Hwang
    Aug 6, 1999
    204
    Mark, a question. In the in-room response graph, how much power was applied?
    thanks
  8. chris hunigan
    Jan 4, 1999
    17
    Kyle G,
  9. Kyle G
    Kyle G Auditioning
    Jul 25, 2000
    11
    >>Okay what I heard from both the coffee table sub and my Twin Sealed sub was a MESH MADE IN HEAVEN. I mean the two together blended wonderfully within our room.
