So I have been having a odd issue with my Harmony Hub and the Watch TV or Turn on to Chromecast action. It was working fine for months then this issue cropped up last 2 months.
When I hit watch tv it boots up the cable box and sound system and even starts playing the tv sound thru speakers, but it does not turn on the TV. When I try to fix it using the app it just does not work on the tv at all. I can't even manually turn on the tv using the app, I have to go and pull out the legit Samsung TV remote to boot up the tv. Same thing occurs when time to turn off it will not turn off the tv, have to do it manually. The issue comes and goes it will work for 5 times, and then fail 3 times.
I have tried to reset the hub when everything is fully off, it does not fix it. I have tried unplugging it for ten minutes to let it reboot.
Everything short of recreating the watch actions I have tried.
Any help is appreciated.
Samsung TV, Harmony Hub with Companion remote, (issue works with the remote and the app launching the activities)
