Harmony 880 & Hot link Pro together??? (1 Viewer)
paul koster
I am in the beginning stages of getting a room ready for the transformation. I have the A/V eqipment and the room has had wiring put in from a previous owner. I still have a decision to make as where to place the A/V eqipment. It's come down to a hall closet or in the room in a cabinet. Prior to having the closet as an option, I puchased a Harmony 880 remote to eliminate the many other remotes.
My question is this: Will the Hot Link Pro work with the 880?
I know that Logitech makes a RF receiver but it does not work with the 880.
If the Hot Link Pro does not work with the 880, what will?
All suggestions are appreciated
Thanks-Paul
Robert_J
Mississippi
Could you please give some details or link to the Hot Link Pro? If it is an IR relay system, then it should work. I use my Harmony 880 with ChannelPlus IR equipment.
-Robert
paul koster
Sorry: forgot about the link
Here's the link to the hot link pro: smarthome.com/8225p.html
It appears that it's an IR extension. I would think that if the 880 works like your other remotes than there should be no problem.
Robert_J
Mississippi
The 880 will work fine with that equipment. Remember that it outputs the same IR signal as your stock remotes.
-Robert
Don.l
Don
You could go much cheaper buy buying stuff from Partsexpress.com That's what I did and it was very simple and easy to setup. Same thing as the HotLink, but cheaper.
Don
gyao
