Harmon Kardon 520
Discussion in 'Archived Threads 2001-2004' started by Greg Kolinski, Jan 8, 2003.
  1. Greg Kolinski
    Greg Kolinski Second Unit
    Oct 13, 2002
    331
    I have been hearing a lot of stories of right rear shannel
    inop in Logic 7 mode lately.I dont have mine running the 7 speaker setup so I dont know if mine is affected.Is it just some of the 520's or do all of this model have this flaw?
    Greg
  2. Jose G
    Jose G Supporting Actor
    Aug 18, 2002
    568
    From what I've read, not all models- but some models. The good news is that if your 520 has this problem- HK may offer to upgrade your 520 to the 525. I know this has happened to a member here on the forum. So hope you don't have the problem...hope you do have the problem...er...hope it works out for you.[​IMG]
  3. Greg Kolinski
    Oct 13, 2002
    331
    so its not like a bad production run,just hit and miss?Some work some dont?
  4. Hal_J
    Hal_J Agent
    Jul 29, 2002
    44
    mine's fine. im wondering if we all shared S/N's if we would learn about builds. obviously the companies do this, and if they find that all the ones made in such and such a week have a broken right rear channel, someone figures out why...
    or possibly we dont have enough of us to see any trends...
    as an engineer, i find the biggest problems with *my* designs begin the day the mfg folks get ahold of it... [​IMG]
  5. Dave Jewett
    Dave Jewett Agent
    Apr 25, 2002
    34
    Mine has the bug, manufactured in Feb. 2002... I do get some sound from the SBR channel, but it's all low frequency. I'm planning on calling them about it this week.
    For those that have the 520, you can test for the bug by disconnecting the jumpers from one of the channels (I used the FR and input) and connecting an RCA cable from the SBR preout to the FR main input. If you have the bug, you'll either hear nothing from the FR channel, or you'll hear just low frequency sound.
    Dave
  6. James Zubb
    James Zubb Stunt Coordinator
    Feb 28, 1999
    147
    I have a 320 and have the problem. I haven't bothered contacting HK about it since I don't use it. I just hooked the SBR out to my powered computer speakers to test. Mine has a manufacture date of April 2002.
  7. Jose G
    Aug 18, 2002
    568
    Dave, are you talking about going into the unit to test? If so, this may void your warrenty- careful, especially if HK might upgrade you to the x25 model otherwise.
  8. Dave Jewett
    Dave Jewett Agent
    Apr 25, 2002
    34
    Jose,
    No, you can test for the bug without opening the unit if you have a 520, since it has Main Inputs. There are jumpers connecting the main ins to the corresponding preouts on the back of the unit, so you can disconnect one and use that main input to power the SBR channel temporarily. I found that the test tones in the setup menu worked OK, as did 7 channel stereo, but in Logic 7 mode I got very little sound from the SBR channel.
    At this point I only have 5 speakers and a sub hooked up but I'd planned on going to 7.1 in the future so I need to get it fixed or replaced, otherwise I wouldn't worry about it...
    Dave
  9. Jose G
    Aug 18, 2002
    568
    Yes, I would get it corrected also- the upgrade path must be clean- even if it's just potential sound for now- one never knows about the later.
  10. Greg Stamm
    Greg Stamm Auditioning
    Sep 20, 2002
    9
    Mine also has the problem - not sure if I'm going to get it fixed.
    One thing to note is that if you accept an upgrade to the AVR-525, the 525 doesn't have MAIN IN's, I don't believe.
    Greg
  11. Baldemar Garcia
    Baldemar Garcia Stunt Coordinator
    Feb 4, 1999
    141
    Well poo, I didn't know this affected the 320s also, but now I find that my 320 is bad. Pretty sure I won't use this feature, but I hate giving money to companies that keep putting out defective product. Decisions...decisions.
    Are the two back surrounds in Logic 7 supposed to be mono, or do they have different content?
  12. James Zubb
    Feb 28, 1999
    147
    The back surrounds in Logic 7 are stereo. The DTS-ES is mono which is why I think that works but Logic 7 doesn't.
