Harman Kardon power rating?
Discussion in 'AV Receivers' started by gregg hh, Dec 23, 2003.
  1. gregg hh
    gregg hh Auditioning
    Dec 13, 2003
    8
    I was considering the purchase of a Sony ES until I read alot of the feedback on this site. As Harman Kardon seems so highly regarded, I checked their site, and was suprised to see the lower per channel ratings (50w). I'm a newby, but from car audio a decade ago I realize some ratings are understated, others overstated, etc... I also want to say the "high current" makes a difference...... can't remember.
    Anyway, I need a quality unit to cleanly power five Ascends. I will never listen to music on this system, just movies.
    That being said, do I need a tuner or just an amp and DVD? If reciever what are the good peices in the $500-600 range?
    Sorry for my ignorance. Thanks for your help.
  2. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    Usually a reciever/amp has a turner, but you said you wont listen to any music so the tuner is not important. To play movies you will need a reciever/amp a DVD and a TV for video.
  3. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    high current amps are always good.
    http://www.geocities.com/Area51/Holl...1/ratevsac.htm
    Check the site I listed below, you will see HK is the only one to actually have passed what they rate for power on all there recievers.
    Good luck on your decision. Also, everyone likes the sounds of different recievers, so even though the HK may offer more power, you may like the sound of Denon instead...
