JasonWaddington
- Aug 7, 2002
Ok, ive narrowed my receiver search to these. Which is the better product? I can get the HK for around 600 or the Marantz for around 500. I use my system for %80 music.
I use towers for fronts (JBL N38II) and have no intention of buying a subwoofer.Angelo.M - With a -3dB of 45Hz on the N38s, you are basically missing out on the bottom octave. This octave is extremely important for realism in movies. This is not necessarily the same for music, but there is plenty of music that easily goes into the low 30s.
Are there any bass-management issues one would have to be aware of when comparing the 6200 and the 320/520. I use towers for fronts (JBL N38II) and have no intention of buying a subwoofer. Is there anything that would push me toward the Marantz or the H/K, with respect to bass management?John is completly right, the crossover of the reciever is 100HZ, I have S26 that could go much lower than this, and I wished that marantz could consider including 80Hz in the next series. But dont get me wrong, is still sound amazing.
I dont know in the crossover of the 320/520, maybe someone can tell you this, but for me both are very similar. To be honest with you, I bought marantz because in guatemala we dont have may stores that sells this kind of equipment (only two), and the price is super high, almost double of what you could get in the states. But he offer me two things that sold me beside the way it sounds, one was upgrade to next series with a little amount of money. And warranty, which will be very difficult to get online. But for me the sound you get from Marantz is very particular, no other brand can get close, well maybe Harman Kardon. But from now on I will only buy Marantz, I'm just waiting for the SR7300 to be out and I will upgrade.
Hope this helps,
Pablo Abularach
Subwoofer Crossover Frequency: when the front speakers have been set to Large, the crossover choices are 40Hz or 60Hz to match the typical crossover points of full range speakers. When the front speakers have been set to Small, the crossover choices are 80Hz or 100Hz to match the typical crossover points of the smaller speakers used in satellite speaker systems.
