Harman Kardon AVR320 or AVR320-Z or AVR325?
Discussion in 'Archived Threads 2001-2004' started by Jeremy K, Oct 14, 2002.
  1. Jeremy K
    Jeremy K Stunt Coordinator
    Oct 10, 2002
    98
    I keep narrowing down my search for a new reciever, and am currently looking at the H/K. I am hoping someone can tell me the difference between these models. I found the AVR320 at J and R for $400, and I found the AVR320-Z at Harmon Audio for $400. My question is, is the Z just because it is refurbished? If not what is the difference? My other question, trying not to call J and R is, what is the difference between the 320 and 325. The 325 has 50W x 7, the 320 has 55W x 5, anything else different? And anyone know the price and availability of the 325, J and R doesn't say much, just gives a number to call and Harman Kardon' website doesn't even have info yet.
    The other option would be a Marantz SR5200, but the best price I found was $550 at Cambridge Soundworks(www.hifi.com). Does anyone have a better price on the Marantz, I really liked the Marantz when I listened to it, but can't justify the extra money.
  2. Kelly Scott Rickards
    Kelly Scott Rickards Stunt Coordinator
    Jan 26, 2000
    225
    the 325 has dts neo 6 and has independent xover adjustments for each pair of speakers (mains,front and rear centers, surrounds), ala the Anthem AVM 20
    One big question I have is does this round of H/K recievers (325,525,7200,1001)apply Logic 7 processing to 5.1 sources (Dolby Digital, dts) as is the case with the HK 8000?
    Apperently the 325 manual says *no*, but the reciever itself may say *YES* as is the case with the HK 8000
  3. Shane Yates
    Shane Yates Stunt Coordinator
    Oct 7, 2002
    100
    HK 320-Z is a refurbished unit with a warranty from HK, however JR might not be an authorized HK dealer and there may be warranty issues if you need a repair or something.
  4. Juan M
    Juan M Stunt Coordinator
    Mar 7, 2002
    57
    I've heard from others on this board that the refurb models may not come with remotes. J&R is listed as an H/K authorized internet dealer.
  5. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
  6. Allen Longcor
    Allen Longcor Supporting Actor
    Oct 21, 2001
    546
    I believe the 320 does not have DD-EX and the 325 will. Plus it will have 7 powered channels. I believe those are the two big differences not mentioned so far.
  7. Tom Camlioglu
    Tom Camlioglu Stunt Coordinator
    Aug 2, 1999
    145
    Kelli,
    I own the H/K 8000 and only it and the Lexicon brethren will apply full Logic7 to DD5.1 and DTS.
    Nothing else will.
    Tom.[​IMG]
  8. Chris Purvis
    Chris Purvis Stunt Coordinator
    Dec 11, 2001
    151
    I have a 320-Z. The 'Z' just designates that it was refurbished. And it came with both remotes.
    Most of the above information is correct, however the 320 DOES do dts-neo 6. It does NOT do DD-EX. The 325 will do DD-EX and has 7 powered channels vs the 320's 5. And the 325 will NOT apply Logic 7 to 5.1 sources. It has a different processor for Logic 7 than the 8000.
  9. Laszlo
    Laszlo Stunt Coordinator
    Oct 8, 2002
    64
    what about the 520?? Does this one 7.1?
  10. Chris Purvis
    Dec 11, 2001
    151
    nope. this has been discussed a lot here. The only H/K branded processor or receiver that does Logic 7 on 5.1 source material is the AVR-8000 despite what the confusingly worded manuals say. This is also the case for the 325 and 525. Logic 7 on 2.0 sources only.
    edit
    sorry - if you mean 7.1 period then yes, the 320 and 520 will create a 7.1 mix from stereo sources if you use logic 7. But they will not enhance dts or dolby digital material in this way.
  11. Jeremy K
    Oct 10, 2002
    98
    Just wanted to say thanks for the help. I found a local Marantz dealer with the SR6200 for $599, so I am planning on picking one up tonight.
  12. Cooper_B
    Cooper_B Agent
    Sep 26, 2002
    38
    Another big feature of the 325 is analog bypass on stereo inputs, whereas the 320 will always digitize its inputs. This is hugely important if you are using a decent CD player via analog RCA cables. This extra Analog->Digital->Analog process destroys any benefits the DAC might have had in your CD player.
    If you are using a digital connection from a CD player, this is not an issue, though I believe that most stand-alone CD players will sound better when connected through analog (no jitter issues, and the cd player should have better DACs anyway).
    As for the Marantz, I believe they have a fixed 100Hz x-over for the subwoofer, which is not exactly proper these days. Above 80Hz, it's easier to hear the subwoofer's location as separate from the speakers. With music, though, I'll bet the Marantz will be better.
    -Cooper
