Hard Drive wipe
Discussion in 'Archived Threads 2001-2004' started by Kevin_Graham, Jan 28, 2002.
  1. Kevin_Graham
    Kevin_Graham Stunt Coordinator
    Mar 1, 2001
    131
    I'm helping a friend tonight clean up an old computer so that he can give it to his sister-in-law. It has his business financial data on it and he wants to permanently wipe it off. I've heard that there's a free wipe disk program from the Department of Defense that you can download. When I did a search I got back hundreds of hits for software not offered by the Department of Defense. Is there such a program?
  2. JonahWicky
    JonahWicky Stunt Coordinator
    Dec 18, 2001
    59
    The DOD stuff is just a standard for the number of times the data area is wiped and overwritten. I've used BC Wipe, a freeware program that will wipe to the DOD levels. You can download it here: BC Wipe
  3. Rob FM
    Rob FM Second Unit
    Jan 15, 2001
    474
    3
    110
    R
    I think NORTON has a wipe utility.
    The DOD has different levels of wiping...one method writes all "1"s on the disk, erases them and then writes all "0"s......it does this like 7 times!!
    I've seen other methods that write alternating "1s" & "0s" to the disk.
    Good Luck,
    ~Rob
  4. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    I think that the fdisk utility would be a lot easier. It resets the blocks on the drive.
    Glenn
  5. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    Glen,
    FDisk rewrites the parition table. The data could be restored using some heavy duty data restoration tools that I doubt this persons sister-in-law would have. A wipedisk program actually zeroes out each block.
  6. Glenn Overholt
    Mar 24, 1999
    4,203
    Then this 'sister-in-law' can't be trusted. Hmmm? Not good. [​IMG]
    Glenn
  7. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    If you use Ghost, there is a utility included on the CD called GDISK. This is a comman-line driven replacement for FDISK (and much better, I might add). It includes a /DISKWIPE option which can be configured with as many 'passes' as you like - including DoD standard.
  8. Kevin_Graham
    Mar 1, 2001
    131
    Thanks for all the replys! I went with the BC Wipe and it couldn't have been easier.
