Larry_S
- Aug 26, 2003
I want to mount these speakers above and behind my seating area in my living room. I will be running my speaker wires through the wall, into the attic and down the wall behind where I would view. The wall only comes down about 1.5 ft from the ceiling where I want to mount them. The speakers weigh about 3lbs each.
My question is, Is it ok to just get a long screw into the stud of the wall, and use the screw mount that is on the back of speakers? I know that's what they are for, but not sure what you guys would recommend. I initially thought I would need a speaker wall mount, but that doesn't seem to be the case. In this setup, I'm not sure how I would get the speakers to tilt down, but would it work?
