Halogen Lighting with dimmer Help!
Discussion in 'Archived Threads 2001-2004' started by Marc Fr, Aug 15, 2001.
  1. Marc Fr
    Marc Fr Auditioning
    Aug 13, 2001
    5
    I have my system located in a room with track halogen lights. The lights are on a dimmer switch rated for 900 watts. I have an extremely noticeable buzz on my system at all times now only when the lights are on. I have tried isolating the power to the system on its own circuit breaker, changing the dimmer, but neither worked.
    I am running all power to the system through a Monster protector.
    Is there a line conditioner that will correct this?
    Is there a dimmer that will not give feedback?
    Does anyone have a solution?
    Any suggestions, would be appreciated.
    Thank you.
  2. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    What brand of dimmer are you using now?
    Is it Lutron that folks recommend for HT and cutting down interferance?
  3. Marc Fr
    Marc Fr Auditioning
    Aug 13, 2001
    5
    It is the top of the line lutron Dimmer
  4. Kerry Hackney
    Kerry Hackney Stunt Coordinator
    Oct 18, 2000
    206
    If you have the track and HT on seperate cicuits turn off the track breaker... If you still have the hum/buzz it isn't the track transformers. Maybe a ground problem instead??? Check the grounds where the track is fed. Lutron usually has pretty good dimmers. I don't know what model you have but is it rated for low voltage dimming? There are different dimmers for each application.
  5. Leo Kerr
    Leo Kerr Screenwriter
    May 10, 1999
    1,698
    And, of course, don't forget two other sources of dimmer-noise...
    low-voltage transformers (either magnetic or electronic; they both can be noisy in their own ways..)
    the filiments inside the bulbs can also "sing." Very annoying, that, and sometimes not easy to cure without going to a completely different style of lamp.
    Leo Kerr
    [email protected]
  6. Mike LS
    Jun 29, 2000
    838
    Yes....that's something I've heard too. That puttting some more expensive bulbs in the lights can sometimes cut the hum out as well.....if you're using cheaper bulbs now.
