Terrell
- Dec 11, 2001
I tried a search function, but I can't find the answer to this. I know it's probably been discussed. What are the main differences between the theatrical cut of Halloween, and the television cut that has material added in? Can someone give me an overview of what those scenes are?
Also, I purchased the THX certified Halloween tonight, the theatrical cut version from Anchor Bay, with the new Dolby Digital 5.1 soundtrack and anamorphic widescreen. The transfer and the DD track are amazing. But obviouslt the Limited edition with both versions are out of print. To someone who knows, is it worth it to go ahead and by the Restored TV cut of the film to go along with the THX theatrical cut I have now, ir is there not much difference? My understanding is you can basically get the Limited Edition, but you'd just have to buy the THX theatrical cut DVD, and the Restored Television Cut. Is this correct, and is it worth it? Thanks.
