Halloween II glitch
Discussion in 'DVD' started by ScottR, Aug 24, 2006.
  1. ScottR
    ScottR Cinematographer
    Apr 1, 2000
    2,646
    Some weird glitch happens on the Universal Halloween II disc. It's when Laurie first arrives at the hospital and they are sticking a needle in her arm. On my disc, there are purple bands that flash on the screen. I can't tell if it is the film print, a glitch during mastering, or my disc. Can someone check their copy? Thanks!
  2. TravisR
    TravisR Studio Mogul
    Nov 15, 2004
    27,715
    4,508
    It doesn't happen on mine.
  3. Colton
    Colton Supporting Actor
    Jan 12, 2004
    795
    I think it's your DVD player. Sometimes mine will display white bands across the screen that lasts several seconds. If I play the DVD on another player - it doesn't happen.
    - Colton
  4. ScottR
    Apr 1, 2000
    2,646
    I've tried it on two players. I don't think it is the disc. It looks like it may be in the film print.
  5. andySu
    andySu Cinematographer
    Apr 7, 2006
    2,669
    502
    Well you should hear the region 2 DVD good heavens above the mix has got dialogue bleeding all over the fronts, but then again it is a slasher movie.[​IMG]
  6. TravisR
    Nov 15, 2004
    27,715
    4,508
    I looked at my copy and did see it. Originally, I thought you talking about an actual major purple line going across the screen. If it hadn't been pointed out, I doubt I'd have ever noticed it.
    Anyway, it's also on the Goodtimes release too.
