RyanW
Grip
- Oct 15, 2002
Anyone know if the H/K in remote EZ Set process is a viable alternative to an actual SPL?
Thanks!
Thanks!
It's pretty close to the results I get with a Radio Shack SPL meter. I belive it was 2db out at the most.really? that's encouraging. can you tell me, are you supposed to aim the remote at the speaker making the test tone? following the instructions, I just sit there with the remote in my hand, arm extended towards the tv as it goes through the tones. wondering if my low right surround level has anything to do with me not pointing it at the speaker or something?
also, did you do the sub with it via the color of the LED?
