H/K AVR8000 Amp Assignments?
Discussion in 'Archived Threads 2001-2004' started by Patrick D, Oct 22, 2002.
  1. Patrick D
    Patrick D Stunt Coordinator
    Jun 13, 2001
    65
    I've read in multiple places that the H/K 8000 allows for assignment of its internal amps. In fact, that was part of the prime reason I bought it (putting a nice 2ch amp on the mains).
    However, I can't seem to find any mention of this ability, or how to do it, anywhere in the documentation or on H/K's website. [​IMG]
    Does anyone know if this was just a rumor or if there really -is- a way to assign the internal amps to different channels?
  2. Gregory Scott Bass
    Gregory Scott Bass Stunt Coordinator
    Jun 30, 1997
    180
    Im counting on this feature too...mine is suppose to be here in a week or two.....from what I understand this is accomplished through the jumpers in the back....nothing to do on the front side ??
  3. Chriss M
    Chriss M Second Unit
    Dec 14, 2001
    320
    you can use the amp section of the 8000 exactly as you would a seperate 5channel poweramp. It is not a software feature, there are actually amp inputs on the back panel of the unit. As delivered from the factory, there are jumpers which connect the pre-outs to the amp-input for each corresponding channel. All you need to do is remove this jumper and use interconnects to configure the amp section for your needs.
