H/K AVR630 OSD Question
Discussion in 'AV Receivers' started by TonyWright, Feb 18, 2004.
  1. TonyWright
    TonyWright Second Unit
    Jan 25, 2004
    272
    I recently purchased an H/K AVR 630 and I can't seem to figure out how to get the on screen display to work. It should be as simple as pressing the OSD button on the remote, but when I press that button the screen is blank.
    I'm pretty sure the video switching is working as I have a dvd player hooked up to one of the component inputs and the monitor out on the receiver is hooked up to my TV. The DVD player displays properly, I just can't get the receiver's on screen display to show up.
    Is there something that I missed?
    Thanks in advance for your help.
    Tony Wright
  2. GregorySB
    GregorySB Extra
    Oct 13, 2003
    20
    Check your manual to make sure, but I don't think the OSD will work over component. You have to use S-video or composite.
  3. TonyWright
    Jan 25, 2004
    272
    Greg,
    I think you're right. I'll need to run the monitor out s-video to the TV to use the OSD. It makes sense to me now after having looked closer at the outputs on the back of the receiver.
    Thanks for the reply!
