H/K 525 Banana plugs
Discussion in 'AV Receivers' started by Natelabo, Aug 26, 2003.
  1. Natelabo
    Natelabo Stunt Coordinator
    Jan 29, 2003
    71
  2. Jay Blanchard
    Aug 19, 2003
    23
    Heh, funny. I just bought an H/K 525 and 20 of these same plugs from Ebay [​IMG]
    You can see from the back panel of this receiver:
    http ://www .harmankardon. com/back.asp?prod=AVR%20525&cat=REC&sType=C
    All the L/R connections will work with dual plugs, except for the speakers themselves. I figured that I would just cut the plastic piece to separate them for the speakers and sub.
  3. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    I had problems with some dual banana plugs that I had purchased to use with my Denon receiver. Actually, my plugs also looked the same as those in the pictures. I had to separate them by splitting the plastic apart. It was a pretty easy process - and I saved quite a few $$ rather than going with the Monster plugs.
  4. SeanA
    SeanA Second Unit
    Feb 16, 2003
    329
    Check out AR's PR407 banana plugs on Amazon.com. They are single plugs, but come with a plastic adaptor you can use to turn the singles into double plugs if you desire. I was very pleased with the purchase... < $10 for 2 pair. They are gold-plated, very easy to use, color-coded (red & black bands), and look great too.
  5. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    Sean:
    So you picked up the H/K?
    Nice choice on the AR banana plugs, especialy for the back of the receiver.
    The AR plugs are a little shorter in over-all length. The contact pin itself is of normal length though. This may not be a problem for some, but if one has "limited space" behind the receiver, that extra shortness in the AR banana plugs can help.
    Nate:
    Nice choice with the H/K receiver.
    Good to see another MI member, your just down the road a bit from me.
    Cheers
    Geoff
  6. SeanA
    SeanA Second Unit
    Feb 16, 2003
    329
    Geoff,
    I just order the AVR225. I almost bought a refurbished unit for about $265 shipped, but than discovered a brand new unit through Amazon (actually J&R) for only $350 shipped. Can't wait to get it hooked up !!!
    I am still waiting for more of the AR banana plugs though. They must be popular because they have been on back-order for several weeks. I have the plugs running to my main front speakers already and I ordered more for my receiver connections. I have the speakers bi-wired and I am pretty sure I can get two sets of wires into one banana plug for the back of my receiver. I tried it out and there seems to be plenty of room in the plugs for two wires, though I can't tell you what gage my Monster wires are. Typical for Monster... the gage isn't on the wires or on the reel or in any of their literature.
