Guyza
- Dec 16, 2002
Hi,
My getup consists of H/K 525 rcvr, 6 dahlquist qx6, 1 svs 22-31 Pci.....so far so good.
Now....after connecting everything up, I went to EzSet to do a quick calibration (AVIA disc is on order). I calibrated in Dolby mode and was pretty happy with the results. Then I put in a DVD that used DTS and was disappointed with the sound. I checked the CHANNEL ADJUSTMENTS and the Dolby cal. numbers weren't present in the DTS mode.
I have a couple of questions:
1) Do you have to run EzSet for *every* surround mode? It seems like if I run it for Dolby, then DTS/Logic7/etc...does not have the calibration settings. Only the Dolby setting.
2) Can I just manually enter the "+db" settings for each mode? Or should I re-run EzSet for each?
3) If I change a speaker from Large to Small, should I recalibrate?
4) If I change the crossover setting for a speaker, should I recalibrate?
The H/K manual isn't exactly clear on all of this and hence my questions.
Thanks is advance,
Guy
Thanks is advance,
Guy
