Guncon2 hookup
Discussion in 'Archived Threads 2001-2004' started by DarrinH, Dec 26, 2001.
  1. DarrinH
    DarrinH Second Unit
    Aug 28, 2000
    301
    Can someone please tell me how the guncon hooks up to the hardware and the TV set?
    I want to get a PS2 and TC2 but I'd like to know how the stuff hooks together.[​IMG]
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    you plug 1 end into the RCA Video out of your PS2, and it has a pass-thru so you just plug it in like normal. Then plug it into the controller port, wa-la
  3. Eric Alderson
    Eric Alderson Stunt Coordinator
    Apr 22, 1999
    249
    If you are using S-video or component connections, you'll need the AV Adaptor from Sony (Model SCPH-10130U). That way you can enjoy the clarity of these higher end connections. It costs around $15 for the adaptor.
  4. DarrinH
    DarrinH Second Unit
    Aug 28, 2000
    301
    Thanks Eric, thats what I needed to know.
    Anyone here verify that it does work with an XBR400 set using the component or Svid?
  5. Jeff Kleist
    Dec 4, 1999
    11,267
    If you're playing on a projection TV, I've heard it works on some, not on others, but for the most part it doesn't work on non-tube sets. Just not bright enough
