Some questions...
Is it necessary to ground each cable run from my sat dish?
And do those grounding blocks degrade the signal at all?
Also... I've got a Terk M58 multiswitch. I need to feed 2 STB's from my antenna in the attic. Would I be better off using a good splitter on the antenna cable and running separate lines to each box, or just let the Terk handle it?
