grounding cable service
Discussion in 'Playback Devices' started by jeff_c, Jul 26, 2006.
  1. jeff_c
    jeff_c Auditioning
    Jan 8, 2006
    14
    I'm rewiring my home for digital cable. I see that the cable company has ran a ground wire frome the outside box all the way around my house to the power meter's ground. Is there a reason for this? wouldn't it be easier to just ground it directly beneath the cable box? Thanks
  2. DougR
    DougR Second Unit
    Jun 15, 1999
    354
    Your lucky the Installer did it by Code !!
    Leave it alone !!
  3. jeff_c
    jeff_c Auditioning
    Jan 8, 2006
    14
    just being curious why is that? I understand its code. But what repercussions are there for not doing so? I'm not going to change it, but I always like the technical reason. Thanks
  4. Julian Reville
    Julian Reville Screenwriter
    Aug 29, 1999
    1,195
    To avoid a "gound loop" : a potential difference between 2 grounds.
    You CAN ground to a rod directly beneath the cable box, but you should also run the ground wire to the house ground.
    MY cable installer grounded to the water faucet 3 feet away from the cable box, not bothering to check that the water pipe going to it was PVC. [​IMG]
    That has since been corrected.
