Jeff AW
- Mar 29, 2002
Ok, after sifting through a ton a old ground loop posts, none really fit whats going on in my system. So.. I am hoping someone can point me in the right direction..
I have the dreaded cable coax ground loop hum. I have a DIGITAL cable box so most of the isolators DON'T work. They leave weird lines through the first 100 Stations and introduce muck into the digital signal....
Here is the odd part. The house I live in is 5 years old. Properly grounded. Our cable company hooked up the cable ground to one of the copper pipes in the house (not sure which one without looking). The cable hits 2 splits before it gets to me. One for the cable modem and one to split the signal to the other digital box we have. My split runs about 70-80 feet before it gets to me. Once at my living room, I get the dreaded ground loop even though my cable is grounded at the point of entry to the house.
Here is what I did to eleviate about 98% of the hum. I stripped some rg6 off at each end of a spare piece of cable, wrapped the bare copper wire around the digital cable box "Cable IN" connector and stuck the other bare copper into the house ground of one of my outlets. This cut 98% of the hum, but there is still some there, low in volume but still there. The hum increases in volume if I switch it to my VCR (Still running off the same cable)
How can I properly get rid of this ground loop? Not sure if hacking an rg6 cable to house ground is the "right" way to do it... At this point I am up for suggestions.
