ChrisAttebery
- Mar 28, 2002
Hey guys,
I'm building a Shiva based subwoofer. I'm going to put a grill on it and have a couple questions about it.
First, I need to know what material I should use to make the grill structure. I was thinking about using either 3/4" mdf or 1/2" abs plastic.
Second, do the push on grill posts raise the grill off the cabinet? If so, how much?
Finally, will 3/4" clearance between the front of the speaker and the grill cloth be sufficient? According to Adire the Shiva has 15.8mm (5/8") of Xmax each way.
Thanks for your help!
Chris
Chris
