After the repairs, I noticed something on one of my component inputs (not on the cable TV, however).
Along the lower left side of the screen, in a vertical direction, there is a bright beam of whitish bar in the picture. Its only about less than 0.5 cm thick at the thickest spot, but when it's a dark room I do notice it. It's about half the height of the set.
Do you think I should call the tech to remedy it? I don't really mind it much, provided it doesn't cause burn-in. I can always wait a 5 months when I will call them for a service menu convergence (they provided me a free one).
white as in pure white or transparent line have you tried to use diff. inputs in the back of the tv and it is there for the games and regular tv veiwing correct
switch around the connections on the back of the set and see if it is still there and make sure the connections are tight :frowning:
1.) It's definitely translucent. It's sort of whitish purplish, but it's see through.
2.) Couldn't see it on Monsters Inc (1.85:1), but could see it on Ronin (2.35:1) and Episode II (2.35:1) and Fight Club (2.35:1).
Any ideas?
I don't know. I'm just so tired of fixing one thing or another with my HT I just want to kick back and enjoy it. I think I'm just going to ignore it. Between work and school,I have enough things to stress about as it is.
But if you have any ideas what it might be, I'm still curious to know.
