Grave, Kiki’s, and Spirited Away problems
Discussion in 'DVD' started by Ian, Jul 16, 2003.
  1. Ian
    Ian Agent
    Aug 7, 1998
    28
    I have encountered a problem with Grave of the Fireflies, Kiki’s Delivery Service, and Spirited Away. Disc 1 (the movie) will not play on my Sony S-7000, but they are fine on my laptop.
    Normally, I can play DVDs other players have problems with. Are there any S-7000 owners who have had problems with these DVDs? I am sending them back to the online store for replacements, but I am wondering if I need to buy a new DVD player?
    Ian
  2. JeffMuller
    JeffMuller Stunt Coordinator
    Apr 18, 2000
    183
    Spirited Away -- at least the copy I rented -- won't play on my DVP-S7700.
  3. Rob Lutter
    Rob Lutter Producer
    Nov 3, 2000
    4,523
    Grave should be totally unrelated, as it was released by Central Park Media and not Buena Vista HV.
  4. TonyDale
    TonyDale Second Unit
    May 3, 2003
    297
    I have a similar problem with other BV/Disney titles as well as with KIKI: two copies of KIKI's first disc will not play on my Panasonic dvd-C220D; whereas it often takes several "disc exchange" or "disc skip" to fire up the second disc of Disney's 20,000 LEAGUES UNDER THE SEA. If I'm very patient, eventually it plays, but nothing but an error message with KIKI's first disc (the second disc plays just fine), and sometimes even SPIRITED AWAY doesn't do it on the first try.
  5. Jeff Kleist
    Dec 4, 1999
    11,267
    There may be an authoring system in common or compressor
  6. Ian
    Ian Agent
    Aug 7, 1998
    28
    Thank you everyone for your responses. Jeff may be right about the authoring system. I should have my replacements by next week. I will post an update.
    Ian
  7. Ian
    Ian Agent
    Aug 7, 1998
    28
    I received my replacement DVDs and I have same problem with all three as before. There must be a similar authoring system being used.
    Ian
  8. CraigF
    CraigF Cinematographer
    Nov 20, 2002
    2,815
    154
    4,110
    Toronto area, Canada
    Craig
    I have all those discs you mentioned, and they play fine on my Panny RP82. However, I *do* have issues with all Infinifilm authored discs. Not big ones, but annoying enough that I don't buy them, even though they play fine on a "lesser" player, luckily I'm not missing much. So yeah, it could be a similar authoring system/method as Jeff mentioned.
