ChrisArmour
- Oct 18, 2003
Hi, I am considering buying either the VMPS QSO626 Ribbon or the GR Research Diluceo monitors both in kit form w/finished cabinets. I have a couple questions, first, which of these two speakers do any of you feel is the better value? Based solely on quality of components. Next, I will be using these speakers for probably about 75-80 percent home theater, I have auditioned the QSO 626 ribbons already(as far as I know, I have no way to audition the GR's), and I was very impressed, I am curious as to how you guys feel the GR's would do for a mostly HT environment? Also, because these are going to be used for mostly HT, do any of you feel that I would be better served by the GR A/V-2 opposed to the Diluceo, or the VMPS 626 instead of the 626 Ribbon, based on performance vs cost? These would be the first speakers that I have ever built and it sounds like something I would like to try, thanks for any input any of you may have, also feel free to suggest any alternatives.
