Got the new studio v3's – why can’t I tell any difference between receiver & amp?
Discussion in 'Speakers & Subwoofers' started by Robert Posey, Jul 8, 2003.
  1. Robert Posey
    Robert Posey Agent
    Mar 4, 2002
    28
    OK, first off I have only had them for a week, so they are not "broken in" yet but still sound very good. 100's in the front, 40's in the rear & just picked up the cc470 center yesterday. My Paradigm dealer loaned me a v2 center and a 5 x 225 Sunfire amp to try out until my new center arrived.
    The first couple of days I ran the all using my Sony 777es (120 x 5) receiver. They sounded great to me that way. For the last 6 days I have been using the 777 as a pre-pro and the Sunfire for power – equally great sounding. I thought I would hear a noticeable difference between the receiver & amp, but I have not. Everyone says the studios need a lot of power, but I haven’t seen it. Could it be the new version is more efficient? Still no info. on the Paradigm web site.
    Trying to keep the db level lower than 100 at my listening position (to save my hearing), but it is hard to do, because they beg to be turned up – the sound seems a little thin at lower volumes – maybe not enough break in time?
    I will continue listening with the receiver today to compare. Maybe at lower listening levels (below 100db), all I need is the Sony.
    Anyone have a similar experience?
  2. keir
    keir Stunt Coordinator
    Jan 16, 2002
    182
    blind tests have shown that solid state amps all sound alike as far as our ears are concerned. many people dont believe that but if you put them in a controlled blind test they wouldnt be able to prove otherwise.
