Got an Outlaw Model 7140 Today (1 Viewer)
gadgtfreek
Jason
Coupled it with my AV7702II. Nice little amp but not much difference from the 7125 it replaces, just newer with some tweaks over the older model (plus a slight power bump).
Size and weight they are basically the same, the 7140 is quieter though, but its not like I could hear the 7125 from my seated position. Power cord is now detachable and the fuse is a 15a instead of a 12a. The new power button design is "better" IMO and this model has XLR's, so I grabbed XLR Belden cables from Blue Jeans Cable and ran those with the 7140 instead of RCA's.
I had been wanting the 7140 for the XLR's, and got a great offer for my 7125 from an acquaintance, so I figured what the hell! These are ATI built amps in California, and you can't beat that for the price, they also must be selling well because I had to wait on mine and the inspect and pack date was 3/9/17. IIRC, the 7125 was their best seller and it makes sense when you consider build quality, number of channels, and cost.
https://www.outlawaudio.com/products/7140.html
Power Output: 140 watts RMS x 7 All Channels Driven simultaneously into 8 ohms from 20Hz to 20 kHz with @ 0.05% THD.
225 watts RMS into 4 ohms @ 0.05% THD
Signal to Noise: >120dB "A" weighted
Frequency Response: 20Hz. -20kHz. +/- 0.1 dB at rated output
Intermodulation Distortion: < 0.05% at rated output.
Power Bandwidth: 5 Hz - >125kHz +0/-3 dB
Damping Factor: Greater than 400 from 10 Hz to 400 Hz
Crosstalk: Greater than -90 dB from 20 Hz to 20Khz
Gain: Voltage gain of 29 dB
Slew Rate: 50v/uSec
Input Impedance: Nominal 50k ohms
Input Sensitivity: 1.2 Volts for Full Rated Output
Remote Trigger Voltage: 3 - 32 Volts DC at 5 milliamperes or greater
Dimensions: (HxWxD): 6” including feet x 17.25” x 16”
Weight: 53.55 lbs
Power Requirements: 120VAC, +/- 3%, 50Hz - 60Hz 1440 watts, maximum
khoole12
