Got a problem with a 15 year old hacker...help guys!
Discussion in 'Computers' started by Derrik Draven, Sep 17, 2003.
  1. Derrik Draven
    Derrik Draven Supporting Actor
    Dec 7, 1998
    936
    110
    Chris
    My girlfriends son is your typical, pasty skinned, reclusive, 15 year old computer hacker.
    He has some way of spying on all the websites that my girlfriend surfs to, along with being able to spy on all her I.M. chats. He's doing this remotely from his fathers, on his own computer.
    She tells me that he supposedly hasn't installed any software on this pc of hers that I'm using, to do whatever the hell it is he's doing.
    She's running windows xp and he told her that it's a hack that's inherent to all xp software.
    This isn't a problem for me; just yet, since I'm running a dinosaur P2/300mhz with win95 but, if you guys read another thread I've posted on here, you'll see I'm about to step up to the plate, buy a new pc and, I'll be stuck with winxp...and the nosey little hacker.
    Do any of you guys have ANY idea what this hack is he's talking about? I want to make sure the little bastard doesn't get one over on me!!!! We have a dsl connection here and supposedly he knows our ip number and uses this somehow to do his spying.
    Do I have to go out and buy some anonymizer software? A firewall? What do I have to do to make sure this snot nosed teen gets the short end of the stick when dealing with me.
    Any help from you guru's is EXTREMELY appreciated!!!!!
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Does your girlfriend have a firewall up? If not, get one, and fast!
    Glenn
  3. Joe Hsu
    Joe Hsu Supporting Actor
    Jul 2, 2001
    812
    Sounds like it's just a case of someone using remote connection? You can just disable it...and no matter what, everyone should have a firewall, so that'll be a good idea too.
    Someone'll probably have a better idea than me tho, so just wait. [​IMG]
  4. Greg Rakaska
    Greg Rakaska Stunt Coordinator
    May 16, 1999
    111
    It could be the Remote Desktop Help service that is built in to XP. You can disable the service, add a DSL/Cable router with DHCP, and a software firewall to thwart any attempt he might make.
    You might also want to download Spybot Search & Destroy, or purchase something like Pest Patrol.
    Chances are he isn't the stereotypical Hollywood teenage computer hacker. If he isn't using Remote Desktop Help service, then he is probably using one of the many available commercial (shareware) snooper programs. Most teenager hackers are "script kiddies" that rely on the work of others to do their damage. If that is the case, then the measures I mentioned will easily stop them.
    If he is a genius, then my suggestions may not work as i am no genius!
  5. JamesHl
    JamesHl Supporting Actor
    May 8, 2003
    813
    If it's remote desktop you can just disable it. Odds are it's a trojan, I don't know what the script kids use these days but it's probably something like back orifice. Most importantly, get a firewall.
  6. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    first up, the correct term is cracker, as in one who cracks. it may seem like nit picking but hacking is not a crime and almost all people that play around with computers are hackers. aside from that the kid doesn't sounds like a cracker just some snot nosed brat who read some garbage on a website about how to take advantage of the less knowledgable.
    next up, cut out the crap with the stereotypes, noone likes being stereotyped so it's rude to stereotype others. this ones a big pet peeve of mine!
    now that I'm done ranting about some of pet peeves lets see about your problem. the absolute simplest method to prevent remote access to the computer is a firewall. zone alarm is a great personal software firewall that you can install on a computer that will limit both incomming and outgoing traffic. pay particular attention to the outgoing traffic as in programs on your computer that attempt to access the internet. just set the local network to high security settings to keep your problems down.
    finally you can just simply look into pulling your computer off the same network as the kids. easiest method is to invest in a router and daisy chain that behind your main broadband router. it's a simple yet effect method for isolating a computer. I used to use this method when I lived in the dorms. your computer will effectively "hide" behind the router.
    anyway, keep us up to date on things.
  7. Jack Shappa
    Jack Shappa Second Unit
    Jan 24, 2003
    411
    (Admin note: Personal attack deleted.) Crackers break into secure areas and do damage. "Hackers" break into secure areas just to prove they can but are careful not to damage things. Hacking into someone else's system is VERY illegal, wether you damage things or not. Grandma poking around her own computer is not a hacker. Hackers consider themselves "honorable" and hold disdain for "crackers" who harm the systems they penetrate.
    - Cryo
  8. Tekara
    Jan 8, 2003
    783
    (Admin note: Response to personal attack deleted. Do not respond in kind, simply use the "Report This Post" icon and let the moderators handle it.)
    but I know that's not true, right? so let me help you out here. It's not a matter of intent, it's a matter of wether or not the deeds are malicous. hackers are not malicous while crackers are.
    http://dictionary.reference.com/search?q=hacker
    "8. (Deprecated) A malicious meddler who tries to discover
    sensitive information by poking around. Hence "password
    hacker", "network hacker". The correct term is cracker."
    now that perfectly mirrors your attempted definition of a hacker. it gives no reference to any damage caused, just "poking" around looking for security holes. As you can see it is a common definition, but nevertheless incorrect.
    here's a great quote from the hacker FAQ:
    http://www.plethora.net/~seebs/faqs/hacker.html
    "Hackers aren't, contrary to media reporting, the people who break into computers. Those are crackers. Hackers are people who enjoy playing with computers. Your hacker may occasionally circumvent security measures, but this is not malicious; she just does it when the security is in her way, or because she's curious."
    remember it is still malicous to gain access to what you do not have permission to access. e.g. it is malicious for someone to break into your house even if they don't steal anything or cause any other problems.
    think of non-malicous cracking like a padlock that you forgot the combination to. it's your padlock, but you can't remember the code to unlock it so you have to crack it.
  9. Tekara
    Jan 8, 2003
    783
    oh and as far as the media, they got a hold of the term hacker back when the term hacker refered to almost all computer users as when computers first came out the only ones that did anything with them were the enthusiests. so when a computer enthusiest was to blame for some crime they where called by the common nickname of "hacker"
    It can be equated to calling someone who plays golf and uses a 9-iron to mame another person a golfer and describing the maming as golfing. After all he is something of a golf enthusiast which qualifies him to be a golfer and he uses his golf equipment to perform his malicous act which would mean he is golfing, no? Of course not, most everyone knows better and would easily think that line of thought to be ridiculous.
  10. AllanN
    AllanN Supporting Actor
    Mar 15, 2002
    950
  11. Ryan Spaight
    Ryan Spaight Supporting Actor
    Jun 30, 1997
    676
    A hardware firewall using NAT (Network Address Translation), such as the Linksys box mentioned above, is an excellent and easy way to lock out this sort of activity. Basically, the firewall assumes your IP address and your PC gets one that is meaningless on the Internet.
    So the kid ends up talking to the router, and not the PC. Which is a far less interesting conversation.
    This will also protect you from Blaster-type worms, without relying on pattern-based virus scanners. (You still need one of those, of course, but a NAT firewall will stop that particular sort of attack cold without needing to know about a specific new threat.)
    Finally, get yourself a free copy of Ad-Aware and run it occasionally to look for spyware-type stuff a virus scanner won't catch.
    Ryan
    Ryan
  12. Jeff R.
    Jeff R. Stunt Coordinator
    May 31, 1999
    175
    My guess is that he has some sort of network sniffer set up. If all the computers go through a hub, the sniffer can be installed on any computer on the network because the hub sends all network traffic to all the computers. If the hub is replaced with a switch, then network is routed only to the destination computer and not shared with the other computers on the network. He would then have to get the sniffer installed on a computer that physically sits between all the computers and the internet which would be much easier to spot.
  13. John_Bonner
    John_Bonner Supporting Actor
    Oct 25, 2000
    664
  14. Bruce N
    Bruce N Second Unit
    Feb 13, 2000
    349
    110
    This is not a computer problem. This is a parent/child problem. Junior needs to learn NOW that this behavior is not acceptable!
  15. JamesHl
    May 8, 2003
    813
    Oh yeah, I didn't even think of a keylogger.
  16. Lee L
    Lee L Supporting Actor
    Oct 26, 2000
    868
    Just have her start going to sites advocating Tough Love and or Military Schools. [​IMG]
  17. AllanN
    Mar 15, 2002
    950
  18. Jason Merrick
    Jason Merrick Supporting Actor
    Mar 2, 2000
    696
    110
    Simi Valley, CA (Los Angeles)
    Jason Merrick
  19. MarkHastings
    MarkHastings Executive Producer
    Jan 27, 2003
    12,013
    3
    Is your girlfriends computer up to date as far as Windows Updates?
    Microsoft announced a security warning on Sept. 10th. Basically, without this update installed, people could hack into your system. Microsoft deemed this a CRITICAL update and said it should be mandatory that everyone update their systems.
    I'd use the Windows update to make sure you've installed this. If this isn't the reason, it's still a good thing to do.
    MS03-039: A Buffer Overrun in RPCSS Could Allow an Attacker to Run Malicious Programs
  20. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    110
    are you sure the kid is actually doing this? He may just be all talk.
