Got $400...Which DVD player should I get?
Discussion in 'Archived Threads 2001-2004' started by Ramon O. Valera, Jul 6, 2002.
  1. Ramon O. Valera
    Ramon O. Valera Stunt Coordinator
    Sep 10, 2001
    64
    Hey guys,
    The DVD player that I have now is the Panasonic DVD-A120. I got a while back once the Matrix came out on DVD months before the VHS version. I just had to have the Matrix. Well I think it's time to upgrade. I have the 36" Toshiba CZ36V61. It's great and I got it cheap for $500.00. But I think it's time to update the DVD player.
    All of your suggestions are greatly appreciated!
    Thanks!
    -Ramon
  2. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    If you can wait a little bit and are happy with Panny performance, the RP82 should be out soon and will be a cross between the excellent RP91 and the 56/60/62 series.
    Personally, I think it will take the market by storm.
    If you need something pronto, I suggest trying to snag the Denon 1600.
