Got $300 to spend on speakers or receiver, what to do?
Discussion in 'Archived Threads 2001-2004' started by ArmenK, Dec 14, 2001.
  1. ArmenK
    ArmenK Stunt Coordinator
    Jan 13, 2001
    89
    Im a home theater newbie so I need some advice. I currently have a Kenwood VR-405 hooked up to four Acoustic Research AR206HO bookshelf speakers, an Acoustic Research C225PS Center channel, and a JBL PB10 Subwoofer. My system is mostly used for watching DVDs and sometimes listening to CDs. I have about $300 to upgrade the system, so I am assuming upgrading the main speakers would make the biggest difference, but If I didm would I have to get a new center channel to match? Please make some recommendation on what to upgrade to make the biggest difference in sound quality and some recommendation on speakers/receivers.
    Thanks alot[​IMG]
  2. ArmenK
    Jan 13, 2001
    89
    After reading around a bit, another option I have is DIY speakers... what do you guys think?
  3. ArmenK
    Jan 13, 2001
    89
    no opinions out there?
  4. Brian Fellmeth
    Jul 30, 2000
    789
  5. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    Check out http://www.speakercity.com
    they have a ton of DIY kits.
    If you're inclined, DIY will save a lot of money and sound great!
  6. ArmenK
    Jan 13, 2001
    89
    what kind of woodworking tools would I need for these kinds of projects? could i get some kind of wood shop to cut the boards for me?
  7. Brian Fellmeth
    Jul 30, 2000
    789
    You need a table saw (or radial arm saw), a router and a circle jig. Having boards cut professionally would chew up a good portion of the DIY savings. Any friends or relatives with these tools ? I would add that DIY is a bad idea if the sole motivation is to save money. You have to enjoy the process.
  8. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    I agree with Brian on the tools and have to enjoy it part.
    Also check out http://www.adireaudio.com. A pair of Kit81 would fit your budget. A pair of Kit281 would go slightly over budget (and I don't think your kenwood could drive the 281).
    If you know some one with the tools, it can be a rewarding experience for you both.
