GermainW
Grip
- Mar 10, 2001
Hi all,
A while back, I came in here looking for advice regarding a dedicated HT/Listening Room that I'm helping my dad set up. We were almost dead certain on using Martin Logans until... until... well, long story! I'm a dissapointed but oh well, what can I do.... "WHEN I HAVE $ FOR MY OWN HT!!" *sigh*...
This is what he ended up purchasing:
B&W Nautilus NHTM1 (center)
B&W Nautilus N802(fronts)
B&W Nautilus SCM1(rears)
Revel S-30 Surrount Speakers (sides..???)
Revel B-15 Powered Subwoofer (2x)
Proceed AVP Processor/Controller
Proceed AMP5 5-ch power amp
Proceed HPA2 2-ch power amp
The money has been paid but goods not yet delivered or installed. I'm hoping to get some feedback from you gurus out there. If the above combination is horrible, I can probably still change the set-up.
A few questions in my mind right now that I need help with specifically are:
1). Why would they throw a pair of Revel Surrounds in the middle of the B&W speakers? I've always read about voice matching and all that stuff, doesn't this go against the "priciples" of speaker matching??
2). Are the rear surrounds (SCM1) too small to match up with the front mains, which are a pair of N802's?
3). For a room the size of 23' by 17', do we really need TWO 1000 Watts subwoofers?
4). How does the name Proceed compare with other brands in the same price range? We were originally going with Lexicon, which, as I understand, is considered #1 by many for its seven channel processing capabilities. Due to the high price, however, my dad settled for the Proceed processor instead. Was this a mistake???
5). Will the Proceed Amps drive the B&W speakers nicely? Is this a good Amp/Speaker match-up?
6). Sub-placement: from the proposal, I see the subs being placed right under the Stewart screen, between the Center and Front speaker(s). I've always thought that subs should be placed in the CORNER, for best performance. Does the designer know something I don't?
7). Since my dad did quite a bit of haggling (got the total price down by about 30%), I am a little worried that the installers might cut costs in other areas (i.e. cabling, etc). How can I ensure that the cables they use for us are of acceptable quality? (A true novice here, as I'm sure you can tell by now) =)
All feedback, comments, advice, etc.. will be genuinely appreciated!
Thanks guys.... (will post pics when we're done!)
