good upgrade receiver? (1 Viewer)
Ryan Leemhuis
What is a good "next step up" from a cheep Kenwood 600 watt receiver from a HTiB be? Secondly, If I buy some better speakers, would I be able to tell the difference in an upgraded receiver?
ChadLB
If you have a all in one HTIB the first thing is upgrading your speakers. You could buy them all at once or start with the fronts and work your way to the rest of them. Then get a receiver.....the speakers are the weakest link usually in a HTIB setup.
PovertyRowFan
