Good surround speaker package, $500-$1000 canadian
Discussion in 'Archived Threads 2001-2004' started by KyleRoussel, Feb 17, 2002.
  1. KyleRoussel
    KyleRoussel Stunt Coordinator
    Nov 24, 2001
    99
    I'm looking to spend no more than a thousand canadian on a set of speakers for my bedroom that I would like to keep for quite a long time, or until I can afford a couple thousand on towers etc. I will also be getting the HK 320 or 520, if that means anything.
    Does anyone have any ideas on a reasonably priced set of speakers in my specified price range? JBL and Infinity are preferred because I can score sweet deals on them.
    Thanks alot everyone!
  2. Steve Stogel
    Steve Stogel Supporting Actor
    Jul 19, 2000
    600
    The JBL NSP-1 setup seems to be a pretty hot topic around here. They seem to be quite a deal. I think they're going for either $220 or $250, and that's shipped (here in the US, anyway). You could then add any number of subs (perhaps Paradigm being there in Canada).
    Steve
  3. Sebastien David
    Sebastien David Second Unit
    Dec 4, 2001
    291
    definitely check out Paradigms, price/performance ratio is very good here in Canada.
    I also like Klipsch speakers, but in your price range it might be difficult to fit the Reference line, which is the one that sounds really sweet.
    but exaclty what are you looking for here?
    does it include the sub?
    or is it just the center/mains/surrounds?
    what's your room size, and do you listen to music or home theater the most?
