good stereo amp and spkr combo for PURELY stereo music application? (1 Viewer)
Cire
Generally, which brands go well together?
I'm looking into a possible Rotel-B&W combo, what do you think?
Thanks.
Edit:
PS: And budget should be around 2000USD maximum. :)
Tom Grooms
How about an Adcom / Dynaudio combo.
GFP-565 or 710 / GFA-5802 / Dynaudio Audience 72's
Now thats some bang for the buck
$0.02
Tim Hoover
I'm in the same boat as Cire, and I'm strongly considering the NAD C320BEE. Not sure which speakers to match with it, though...
Cire
At the moment, I'm looking into a power amp (w/out a pre). A separate pre-amp would come later on.
Thanks for the responses so far.
Mark C.
I went the integrated amp route for my two-channel, Classe CAP-101 mated with B&W Nautilus 804s. Breathtaking!
Scott Oliver
Audio Refinement Complete Integrated and JM Reynaud Twins MK III.
used Naim Nait 5 integrated and JM Reynaud Twins MK III
Other good integrateds:
Unison Research Unico
Blue Circle CS
used Cairn 4808A
Primare A20
used Musical Fidelity A3.2
All of the above integrateds would go great with any of the French speakers; JM Lab, JM Reynaud, and Triangle.
Rich Malloy
Here's a link to Stereophile review(s) of the PS Audio HCA-2 amp. For the purposes of this review, the HCA-2 powers some Quad ESL-989 electrostats, Sonus Faber Cremonas, Paradigm Reference Studio/20s, and Revel Ultima Studios... any of which would unfortunately exceed your budget when paired with this amp.
Still... worth a look and a listen IMO: http://www.stereophile.com/showarchives.cgi?729
OttoIsHere
