Hi, first post...
I have a Yamaha DSP-A1 (http://usa.yamaha.com/products/audio-visual/hifi-components/amps/dsp-a1_black__u/), which was the flagship recevier/amplifier in the early to mid 2000's. It's at least 10 years and is in excellent condition (I don't run it hard since I live in a condo). However, the front LCD no longer works and while I could have it fixed, given its age and new technology, I'm wondering what my options would be with today's technology that I might consider.
It's been a while since I've researched recevier/amplifiers so I'm a bit out of touch, hence this post.
Here's what I'm using it for to give you a sense of what might be a good recommendation:
I don't plan on changing any of the other components. Given all of this, can you recommend something under US$1000 that would be comparable or good as a replacement?
Thanks so very much!
- HTPC - hooked up to play games and watch Netflix (mostly action genre)
- HTPC - All music is high bit mp3 or FLAC (mostly rock, house/EDM)
- Playstation 4 games and occaisonal dvd or blueray
- Primary focus is on listening to music and playing PS4.
- 5.1 is fine
- I run Paradigm Cinema Phantom v3 series fronts and center, fairly balanced overall in tonality with a slight skew to less brittle highs (if that makes sense). Details here: http://www.hometheatersound.com/equipment/paradigm_system_three2.htm
- I also run a small Yamaha sub and two average sized B&W rears.
- No other pre-amps or anything.
- HTPC and PS4 via HDMI to my TV and Optical out from TV to the Yamaha.
- Don't think I need any bluetooth/ipod connectivity
- Not planning on critiquing classical music or need the most natural sounding processing. I also don't need crazy bass boost either.
- I like a punchy clear sound who's dynamic range can be dialed down at night.
- I would like a reasonable number of good processor effects (the DSP-A1 has too many imo)
