Mike Coady
- Feb 2, 2003
I'm having to rearrange my Home Theater and Audio setup so I'm needing longer speaker cables than I currently have. I need about a 12' run going to some large 5 - way towers (about $3000). There was a time when I wouldn't even consider using anything but the best cables out there when it came to speaker cables and interconnects but I can no longer afford to do that. Through the years I've used Discovery, Audioquest, Tara labs, Kimber, Cardis, Sonoran, DH Labs, Straight Wire and many more but I've forgot their names.
My instincts tell me not to use cheap cable for my revealing speakers but my budget says otherwise. So would something like Blue Jean cable's Beldon 10 or 12 gauge be something I could live with or is there something better out there that is inexpensive but very good quality? I would like to spend $100 or less for a 12' pair if possible.
I'm also open to buying used speaker cable so where would a person look besides Ebay?
