Garrett Lundy
- Mar 5, 2002
I may decide to move my HT set-up from my main living room, to a much smaller unused bedroom. The living room has 7 windows, and you'll need a degree in mathematics to tell me what shape it is (Its about 14' on one wall, 20' on another, with a corner closet in one spot, with a half-wall in another area, blah blah blah)
Anyway... possible Ht-room features
*roughly 8' wide by 14' long 7' ceiling (I plan to use soundboard or other sound-proofing elements on the walls)
*No windows
*one door (on a 12' wall)
Now assuming a chair is 3' deep, leaving 11' viewing area to the wall, how big a monitor should be good? (I was planning on a 16*9 RPTV , plasma is too much $$$ and a 24" deep RPTV would leave 9' of viewing space..so the 65" Sony is probably not too great an idea)
And since the room is so small... what kind of sound system should I think about? a 100watt reciever sounds like way to much when you consider the surrounds are three and a half feet from your head.
I've liked the sound of my Kenwood HTiB (I believe a 407, reciever & speaker set-up,no DVD-player included). But i think it may be too much. Maybe a unit with fewer watts (Such as the Onkyo envision)? Seperate amps seems far too overkill. But I also plan to pick-up an SVS PCi16-46 (I dont think I'll need the extra power of the PC+ series) because I love them LFE's!
Anyway.. Thanks in advance for any helpful advice
*No windows
