Good headphone amplifier?
Discussion in 'Archived Threads 2001-2004' started by Zane Charron, Nov 29, 2002.
  1. Zane Charron
    Zane Charron Second Unit
    Jul 19, 2000
    458
    Much to my dismay, the modified Pioneer DV-747A that I bought recently has no headphone jack, so those delicious DVD-A and SACDs do me no good since I don't have a stereo or home theater setup, just a widescreen set. BUT I do have a great set of Sony CD2000 headphones that I've been using a cheap discman to listen to.
    Can anyone suggest a good quality headphone amplifier? I've heard and read many good things about Creek Audio's amps. And they are available here in Germany for a reasonable price. Anyone have any experience with them?
    Thanks in advance.
  2. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,394
    Lee
    Grado makes one of the best which I used on my latest professional audio recording.
    There is also a headphone shop online (HeadRoom) which makes great solid state amps at various price points:
    www.headphone.com
    I highly recommend these folks as well and have talked with their competent management team at various hifi shows.
    I hope this helps.
    [​IMG]
  3. Zane Charron
    Jul 19, 2000
    458
    Wow, that really is a cool site. Thanks for the heads up.
    By the way, I wouldn't have a problem running a headphone amp directly from my DVD player via the RCA jacks, would I?
    My headphones are 32 ohms, 106dB/mW sensitivity, 1500mW max. power handling.
  4. Javier_Huerta
    Javier_Huerta Supporting Actor
    Mar 9, 2002
    619
    Grado is only a good headphone amp if you are using it with Grado headphones.
    You might want to take a look at the Antique Audio Labs HammerHead (I think that's the name, should be on HeadRoom). You might also want to try their solid state headphone amps - they are superb. A good hybrid solution is the X-CanV2 by Musical Fidelity.
  5. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
