Good Firewall for work
Discussion in 'Computers' started by Al_S, Apr 12, 2005.
  1. Al_S
    Al_S Second Unit
    Nov 30, 2000
    446
    Does anyboday have a suggestion for a good firewall at work? Looking for something that can be configured easily via a GUI and maybe provides a good cheap VPN.
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Are you interested in controlling what goes out from your network, or are you only concerned with what comes into your network? If your only concern is what comes in, then check out the Linksys BEFSX41. It's got a firewall and VPN.
    This will also work for limiting outgoing traffic, but may be less user-friendly for this option than a software firewall might be.
  3. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    Assuming you have a PC laying around... make sure it either has two network interfaces or put another network card in there, then download either Smoothwall or IPCop. I'd probably go with IPCop.
    http://www.ipcop.org
    http://www.smoothwall.org
    Easy to install and gives very good performance and configurability. You can prioritize traffic, establish VPNs, it has a web proxy built-in to speed up web surfing, you can set up DHCP to hand out IP addresses to the machines inside the network, etc.
    The software is free (it is a highly customized Linux distribution, you do all configuration via a web interface) and if you already have a PC you can use for it you get a great firewall for peanuts.
    What you go with depends a lot on the size of the business too. For larger environments where you need maximum configurability, multiple subnets etc you'll need something pricier. http://www.checkpoint.com/ with their FW-1 are a big player but there are others.
    You also don't mention what your budget is for this...
  4. Christo Ramo
    Christo Ramo Stunt Coordinator
    Jan 30, 2003
    152
    Depending on your budgets, there are 2 that I recommend, sonic or a cisco pix.
